Save Drawing as PDF, Separately
Good aftermoon, I have a drawing with two separate sheets on it. I would like to send a PDF copy of the first sheet to one directory and send another PDF copy of the second sheet to a different directory. So far, I have only been able to send both sheet to a directory. Is there a way to send these one sheet at a time? Thank you in advance for any suggestion or assistance.
RE: Save Drawing as PDF, Separately
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP1.0, Dell M90, Intel 2 Duo Core, 2MB RAM, nVidia 2500M
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
mirisj's suggestion will work in your case.
Chris
AutoCAD 06
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2006 SP5.0 on WinXP SP2
