landfill leachate pumping
I have a pumping station in one of my sewer districts which pumps leachate from a capped landfill. The problem is that after a few months, the pumps and piping in the wet well become clogged with what appears to be iron or clay. The 4" force main is reduced to the size of a quarter after just 6 months. This leads to premature pump failure. Anyone with a similar experience and possible solutions. Thank you.
RE: landfill leachate pumping
Depending on the conditions of the fluid, a filter at the suction might prove useful too.
Might want to mention tto the stake holders that the capping needs to be worked on.
Do you have any ability to dilute the leachate in the station? domestic force mains nearby? a groundwater or stormwater source? Anything?
How much leachate per day is going to this station?
Also, are you sure you are getting 2 feet per second velocities in the FM?
I would also suggest keeping in mind that a pigging station or a pressure cleanout might help. This would allow the Utility to either 1) flush the line periodically or 2) send a "pig" through to clear any obstructions.
You really need to have the waste stream characterized to see what's in it. Maybe chemical addition would work, but I personally hate to think of adding more maintenance headaches to the situation.
The only other solution I can think of is to tap into the FM just in front of the pigging vault and run some temporary piping back into the station. I suspect that since the friction losses would be greatly reduced you could send some pretty good flows through the station & valve vault piping and get a good scouring velocity. Just make sure your pump motors are not power limited before doing so and that you properly restrain the temporary piping.
