How to create custome border styles for notes?
Hi everyone.
I have a question: is it possible to create custom border styles for notes?
The only work around I have found is making the border with a sketch, then creating a block to group the text and its border...
Thank you.
Thank you.
RE: How to create custome border styles for notes?
If you do use a block, check out the attributes of the text in a block. That away the text can be changed if you don't need that note callout like it is saved in the block.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I guess I'll use a block that I will re-use...
