high current bolted connection paste
We have some tinned lugs bolted to copper blocks using bronze bolts and beryllium copper belleville washers, but SS bellevilles may have to be substituted.
A low load test is planned that will last a few weeks.
Future full load testing will likely be done with different lugs.
Connection Options discussed so far:
- torque them up clean and dry
- apply dielectric grease and torque
- apply electrolytic grease and torque
- rub or burnish with dry silver powder/flake, and torque
Internet searches find products and methods for aluminum and aluminum>copper connections, but generally suggest copper>tin is OK by itself.
RE: high current bolted connection paste
I figure if I'm supposed to put some dielectric grease on my spark plug connections we probably ought to do SOMEthing.
update - the copper blocks were supposed to be silver plated, and now must have a green patina cleaned off before plating
