fault current bracing
I have a 480 v motor controller contactor mounted to a back panel, and the panel is mounted in an enclosure with 4 each 3/16 ss 316 bolts (140K PSI each). I know the available fault current is 30kA. How can I determine if the bolts can withstand the fault?
RE: fault current bracing
