Units for Excel outputs
Hi all,
I have two related questions:
1) I have just started using the excel component in Mathcad and I'm having a bit of a trouble getting the output variables to have units. I'm using Mathcad 11. I have a variable named secA which should be in mm. I can make it in units of mm by redefining it as a multiple of itself and 1mm. But I was thinking there should be a better way of doing this.
2) As a further complication, I am getting a "Units in this expression do not match" error for a programming block that uses these values. The problem there I think is related to the fact that I'm assigning (local assignment) the result of my calculation (which has a unit of kN) to an array element that had not been previously defined. I'm lost as to how to correct this problem.
I have posted an image of the programming block I'm using:
Any help would be much appreciated,
Still
Still
RE: Units for Excel outputs
2. You should post your entire file on the Mathcad collaboratory. It's absurdly difficult to debug an image of a Mathcad file. http://collab.mathsoft.com/~Mathcad2000
TTFN
Thanks.
TTFN
