Convert CATDrawing Files from V5 R16 to V5 R14
Is any possibility to convert the drawing files (CATDrawing)from V5 R16 to V5 R14?
Thank you.
Thank you.
Thank you.
Thank you.
RE: Convert CATDrawing Files from V5 R16 to V5 R14
Derek
Proczak,
Do you refer to the 3D data? Basically, I need to convert the drawings (CATDrawing files)from R16 to R14. The 3D is fine.
Rob
Document needs to be converted
WARNING : PartBody is empty (no solid), no conversion
This utility converts the Partbody solid only with the result being a dumb solid.
Rob
if you only want to read the file in r14 then save it to CGM.. or HPGL.
