connecting CRT to Fanuc RH controller
Basics here.  I just bought a used robot with no manuals.  Fanuc has been no help so far.  Can anyone tell me how to connect a monitor to the controller's "CRT" connector?  It's a 25 pin D type on the controller.
RE: connecting CRT to Fanuc RH controller
Yes, I have a same problam in it. Do you think which monitor can use for? and how to connector?
I ended up hooking up the robot to a PC via the serial port on the computer.  I then used a VT emulator running on the PC.
Thank you BobM3 where can find the VT emulator, Do it working with Fanuc RH control?
I liked PowerVT from Dartcom.  There are quite a few you can get for free.  Hyperterminal might work.
My robot has the RH control.  So, yes, it will work with the RH control.
Thank you BobM3. I get the PowerVT. But I can't enabled the teach pendant. So I don't know what parameter setting for the serial port. Do you think any way will disable the teach pendant. Some thing like parameter, program or PLC input pot. I see the system bootup fine. All LED at control panel will light one time when system bootup. Have any way to enabled the teach pendant.
