Single Rotational Constraint
Is it possible to create a single axis rotational constraint at a keypoint(point) in workbench simulation rather than a rotational constraint in all 3 axes? I just want to constrain a keypoint with a similar contraint as dk,,roty would be applied in ansys classic.
thanks
thanks
RE: Single Rotational Constraint
In WB, you can't apply any solid body constraints, because there are none in the input file generated (WB translates all solid body loads to the underlying FEM). So what you'll have to do is insert a command snippet, use selection logic (or create a named selection out of the corner), and then apply the constraint manually.
However, just be careful that you're not trying to apply rotational constraints on solid bodies, since all the solid elements only have translational DOFs.
Good Luck
/prep7
cmsel,s,point1
d,all,roty
allsel
finish
/solution
thanks
