Butterfly Valves: Flow versus # of Handwheel Turns
I've been given some test data on a butterfly valve that I'm trying to validate. My validation information is in gallons per minute. The acceptance criteria was given as being from 22 to 26 turns, and I was told that +/- 2 handwheel turns from the nominal 24 turns equated out to +353 gpm to -426 gpm.
Can I calculate a flowrate assuming a linear increase (i.e., 11*353=3883 gpm) or do I get a larger increase when the valve first opens? What information would I need in order to figure out the flowrate? The valve supposedly is an Enertech butterfly 15".
RE: Butterfly Valves: Flow versus # of Handwheel Turns
Aren't you looking at the data of a globe valve. These valves have a correlation opening x flow rate.
Steven van Els
SAvanEls@cq-link.sr
This does however not mean that the "resistance" introduced by closing the valve will increase linear. As i recall it the flow will only decrease slowly when close and then drop abruptly when the valve is almost fully closed (the last 20-30 % introduceses almost all of the pressuredrop)
Best Regards
Morten
(2) what other information do I need to obtain? I'm thinking gear ratio, percent open at 100% flow, and percent open under normal throttled conditions. But do I need anything else???
thanks
http://www.me.cc.va.us/dept/ietech/water_wastewater/distance_learning/courses/CIV240/butterfly_valves3.htm
This can be done by globe valves, or ball valves with a special bore. These valves have a defined correlation valve opening x flow. This correlation can be linear or some defined function.
Gate valves and butterfly valves are used for shut-off purpose not regulating flow. The correlation valve opening x flow is definitely not linear.
I suspect that your valve has some mechanism and you have to relate turns x valve opening, but to extend that to the low rate would be very difficult
Steven van Els
SAvanEls@cq-link.sr
If you don't already know this, Cv is called the flow coefficient. For liquids, you can quickly calculate the flow rate knowing the differential pressure (DP). Flow rate (gpm) equals the Cv times the square root of DP. DP units are psi.
For a simple start, assume the DP is constant, regardless of the valve position. It probably is not, and there are ways to account for this and have a more accurate prediction of flow rate. However, it would be a textbook long response. Using the equation above, make a curve of valve position versus flow rate.
Now, the gear operator requires a certain number of turns for 90 degrees rotation of the valve. You can operate it count the number of turns or get it from a product catalog.
Just rplace the valve position on the lower axis of the curve with the equivalent number of turns to get to that position. Now you can quickly estimate the number of turns to get a certain flow rate through the valve.
I hope you find this helpful.
BR
In response to another post, butterfly valves can be used for throttling with the current designs. Some of them are designed for essentially on/off service but that isn't universally ture.
Patricia Lougheed
Steven van Els
SAvanEls@cq-link.sr
My thinking is,If The Handwheel is connected to a gearbox(It has to be!)Then The Disc's degree of opening depends on the module and pitch of the worm gear inside the gear box.
Now,The gear box is selected on the Basis of torque value of the valve.Each gear box has a unique value of Torque range of Operation beyond which It cannot be used.For eg.:-
consider a series of gear boxes called eng series then you name it as eng0-150,eng150-250,eng 250-350,eng350-450 etc.The numerical value being the torque range the paricular gear box can operate.Suppose you have a valve having a torque of 275kgm,the gear box selection is done by multipleing a factor of 1.3 to the torque which is 1.3*275=357.5kgm so then the eng350-450 gear box is selected for the valve. Sometimes for reasons of economy the gear box is selected with the minimal factor of safety then the eng250-350 gear box fits in.In the former case you have a larger gear box than neccessary but are assured of it's safe function;In the latter case the gearbox is much smaller and you are saving money too but the flip side is the gear box is not design worthy for higher pressures.Kindly check with your supplier as to how the selection was made.
Also,Find out if the Handwheel is designed for the particular gear box only.
I am sure this info. will help you.
I have seen a lot of words in the replies but....
First the operator:
a 15" you say (funny size not a 14"or 16"?) defenitely requires a gearbox. Depending on the forces required to open & close and the dynamic torque (!) there is a certain gear selected.
Any supplier can tell you the number of turns for a full open to close travel, so for the 90 degrees output.
>>>>Turns
The flow characterisitic for a traditional butterfly valve is equal percentage and tends towards the linear line as it is more off set (double or tripple eccentic BFV's). It will stay more eq% than linear.
There is a characteristic and if not there are definately steps per 10 degree steps available from the supplier.
This must give you a good estimate of where you want to set your valve position for you given flow.
>>>> Flow
There are plenty of inaccurancies in this. What is the medium, downstream/upstream behaviour...how stable is the system, are there more consumers on that same flow
are you sure you do not prefer a flow sensing device and a control valve instead.
Other than some say, you can control with BFV's but this is for Flow control. Not for pressure control while the recovery factor for BFV is high.
Good luck !
