Anchor Bolts in a Circular Configuration
Does any one know where I can find an example of anchor bolt calculations in a circular configuration?  Specifically, I am designing the embedment depth for anchor bolts in a drilled shaft on a base plate with a grout pad.
RE: Anchor Bolts in a Circular Configuration
AISC Design Guide #1
