SW 2007 Rename
6
SW 2007 Rename
SW 2007 Rename
In case you haven't noticed, you can now safely rename a SW file in Windows Explorer 2007 and keep its links.  Right-click a file > Solidworks > Rename
http://www.paul-flores.com/solidworks_screenshots/explorer_2007.jpg
After picking a file, it will automatically search the folder for drawings "where used" similar to SW Explorer 2007:
http://www.paul-flores.com/solidworks_screenshots/explorer_2007_rename.jpg
This will automatically find all files for that particular project and keep the links.  We installed SW07, but are still using SW06.
SW06 SP5.0
Flores
RE: SW 2007 Rename
Good to know.
Thank you!
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
RE: SW 2007 Rename
Very helpful!
Where did you find that little snippet?
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
RE: SW 2007 Rename
Sweeeeet !!!!!  smile
Anna Wood
SW06 SP4.1 x64, WinXP x64
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
www.auerprecision.com
RE: SW 2007 Rename
Thanks, Flores, I didn't read that in the 2007 What's New.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
RE: SW 2007 Rename
6
From Windows Explorer: Right-click a file > Solidworks > Pack and Go, you will get the following box:
www.paul-flores.com/solidworks_screenshots/pack_and_go.jpg
You will see a few options for grabbing the required files, such as simply copying them to another folder, or zipping them. Also has an option to add prefix or suffix.
SW06 SP5.0
Flores
RE: SW 2007 Rename
I didn't know you could do that right there--I don't use SW Explorer, but use Windows Explorer all the time.
Thanks for the info!
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all.  And awe trumps reason.
RE: SW 2007 Rename
very cool smcadman!
Macduff spin
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2006 SP 4.1
Dell 380 XP Pro SP 2
nVida Quadro FX 3450/4000
RE: SW 2007 Rename
Can I admit I found that on accident?  I sometimes right-click > Open with > SW Viewer because I wanted to quickly view a large drawing.  I found that "Solidworks" in the right-click menu and started playing with it.  SW did a good job of meshing SW Explorer and Windows Explorer.
SW06 SP5.0
Flores
RE: SW 2007 Rename
WOW! A five-star cad man!
Chris
AutoCAD 06
