Hot water pipe insulation
I need some help on calculating the insulation specifications on a domestic hot water re-circulating system. I have 200 feet of 3/4 inch copper pipe. Can the insulation be specified based on a heat loss that is a percentage of the hot water used. In other words insulate so that perhaps 5% of the heat is lost in the pipes so the efficiency of the system would be 95%. The system circulates all day but the hot water is used sporatically. I would guess about 100 gallons of hot water are used daily.
Bill
Bill
RE: Hot water pipe insulation
