*USE in *ABBR command
When I call a macro from a macro library by using the *ABBR command with:
*ABBR, command, *USE, macroname
at startup I obtain:
* no longer valid as comment character - please use !
and the abbreviation is cancelled.
Do you know what the problem could be?
andrea
 Andrea Mordini, Civil Engineer, Ph.D.
 http://www.andreamordini.com
RE: *USE in *ABBR command
it works like that:
*abb,command,macroname.mac,arguments
Ansys will first search in the Work Directory and than in the APDL directory.
If you are usig a mcro from a macro library, you must call a macro, who will call the other macro from the library,
CODE
*abb,command,mainmacro.mac ! calls main macro
The content of main macro:
CODE
*uli,libname,ans
*use,macroname
Alex
But in this case I have to write a different MAC file for each macro... there's not a big improvement in using a library...
sadsad
andrea
