Design Table for Hole Wizard
Is it possible to change hole (dia & callout) in the Hole Wizard (for example from 1/2-13 to 5/8-11) using Design Table (Excel) or API?
RE: Design Table for Hole Wizard
API...yes.
Design Table...No, not that I know of.
Ken
A DT can be used to change the holes dimensions, but not the holes feature name or callout.
You could however have multiple holes at the same position and have the DT suppress & unsuppress them as required.
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
Hole Calloutformat.txt file can be customized as well, but under those items you listed.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
