Tilt-up Lifting and Bracing software
Can someone please tell me what software is use to locate Lifting and bracing inserts for tilt-up panels.
Edwin
Edwin
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Tilt-up Lifting and Bracing software
htt
Insanity in individuals is something rare - but in groups, parties, nations and epochs, it is the rule.
-Friedrich Nietzsche
We make a living by what we get, we make a life by what we give.
Sir Winston Churchill
It is expensive but it is very useful in its approach to many differing precast applications.
Many precast lifting configurations are based on simple spans and assumed uniform moments.
Depending on panel capacity, you may require a lifting beam if the panel cannot sufficienty distribute the loads applied for lifting.
Again, buy the manual. Talk to professionals in your area. Ensure you can call yourself competent with regard to OSHA requirements for rigging such a load.
Daniel Toon
See this page:
http://www.microstran.com/faq_tilt-up_panel.htm
The download is at:
http://www.microstran.com/freestuff.htm
Hope that helps,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
