Theoretical burst speed of a disk
This must be a fairly simple equation. I looked through my old physics textbooks from 30 years ago and couldn't find it. I tried to google it, but there is WAY too much information, and NO equations.
-Michael
www.sewellgeneralcontracting.com
ALBANY TROY SCHENECTADY NY
RE: Theoretical burst speed of a disk
Would I figure that the entire mass was at the radius of gyration?
Am I getting close?...
Thank you,
-Michael
ALBANY SCHENECTADY TROY NY
This is a pump forum but your title, which, I assume, is the question, doesn't appear to have anything to do with pumps. I'd suggest forum 404 (Mechanical Engineering - Other Topics). However, if you decide to post there, be sure to leave a note here directing replies to that posting. Also you might want to consider posting your question inside the message, not just in the title.
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
Thank you very much,
Michael
-Michael
Thank you for the advice.
"Looking for calculations/spreadsheet to determine the stresses in a rotating disc caused by RPM. The application is pump impellers."
http://www.eng-tips.com/viewthread.cfm?qid=50738
-Michael
