Tank bottom testing
Tank bottom testing
Tank bottom testing
What is he most common way of thigtness testing the fillet welds of vertical storage tanks of large diameter (50' and more) Design code BS 2654(API-650).
Thanks in advance
RE: Tank bottom testing
Normally vacuum box testing during construction, hydrotest on completion.
Are you talking about the "T" joint welds where the bottom and side join?
No, I mean the butt and lapjoints in the bottomplates.
JStephen put you on the right track.
