Calculating TDH
Calculating TDH
Calculating TDH
When it comes to valves and calculating the TDH for a pump, are there two different pressure drops you need to find?
The pressure drop caused by friction (K factor) and the pressure drop caused by flow separation (Cv factor)?
RE: Calculating TDH
Use one or the other.  K if your units are SSI, Cv if units are English, as in gpm/psi^0.5.
BigInchworm-born in the trenches.
http://virtualpipeline.spaces.msn.com
