Vessel Cladding Thickness
Does anybody have any idea how to determine the required thickness of a vessel cladding? What I have is a CS vessel to be cladded with a CRA. So is there a standard somewhere that will let you know what the minimum cladding thickness will be required. This cladding is only for corrosion protection so its not intergal bonded that yo can consider in determining total vessel wall thicknes for pressure containment. This in a ASME VIII vessel.
Thanks.
Thanks.
RE: Vessel Cladding Thickness
Steve Jones
http://www.pdo.co.om/pdo/
