Helical Spring along Curved Path: any method?
Can anybody tell me a simple method of creating a helical spring along a curved path. The method explained in the knowledge base is tedious.
RE: Helical Spring along Curved Path: any method?
If you are using release 2000i^2 or 2001, I can problably send you a generic spring model that we use. You could use this model, or look at how it was made and create your own.
You can e-mail me at:
jim@tactex.com
http://www.ptc.com/cs/cs_23/howto/ngf1656/ngf1656.htm
Basicly you create a surface sweep along your trajectory and project a curve onto the surface. Then you sweep a circle around this projected curve. Hide the surface with layers.
post a reply if you have problems.
Pro/E Pro
http://www.ptc.com/cs/cs_23/howto/agf1663/agf1663.htm
Doug
