HIGH STRENGTH ANCHOR BOLTS
Does anyone know where I can find the allowable capacity of anchor bolts. I haven't bought the new AISC code yet and I live in concrete country so don't get into many situations where this tyoe of material is needed
RE: HIGH STRENGTH ANCHOR BOLTS
http://www
It looks like ASTM F1554 is what you're thinking of.
You can download these ASTM specs for a fee if you need the information in it.
In the ACI-318 design method, one of the limitations on the anchors is the strength of the anchor itself- based on the ultimate strength of the anchor material. So knowing the anchor material and ACI-318, you may not need anything else.
ht
I'm sure you can also call and they will help
Fyi in my area lead time for obtaining the highest strength (Fy=105 ksi) rods is six weeks +-. (Found this out the hard way when designing a fix for some ab problems on a new building). Suggest you check how available they are before you specify a higher strength rod. Regards
He did mention one other thing is that several of his customers are using fluorescent orange for the 105s and some are using it on B7s.
