Convert string field to date via sql
I have a data field that is a type text in an existing database containing dates in the format mm/dd/yyyy and I'm trying to order the records by that field as a date.  Is there anyway to convert this field to a date within the sql statement and then base the order off of that?  Thanks.
RE: Convert string field to date via sql
Dear gabeshackle,
I am not sure of the database you are using, but most of the database has function to convert one datatype to another. like to_date() in oracle, format() in Access. If the information are not sufficient please feel free to mail me at simp_raman@rediffmail.com , meanwhile update the information here for the benifit of other members.
With regards,
Raman
To use a SUM-Operation in a query it is necessary for me to convert the attribute from data type "char" to another (integer).
How is the syntax for this conversion (convert(char,??)
