COMPRESS BUILD 6251 & COMPRESS BUILD 6252
COMPRESS build 6251
XML file - nozzle required thickness
Nozzle required thickness per UG-45/UG-16 listed in the Nozzle Summary is now exported to the XML file (See the 'requiredTn' tag in the 'Nozzle' element).
COMPRESS build 6252:
Will COMPRESS build 6252 be able to have the following additional XML file for Maintenance and Reliability to export to Meridium to manage and improve asset performance, for Meridium assect management software
http://www.meridium.com/index.asp?bhcp=1
current LNG Project requirement.
