iges files
iges files
iges files
Fresh install of s/w 2004 after installing a new hard drive.  Prior to this everything worked fine.  But now it will not open iges files.
RE: iges files
How are you trying to open the IGES files? By double clicking, or by the regular SW File > Open > Type:igs method?
Did you remeber to disable the anti-virus before installing SW?
cheers
Helpful SW websites FAQ559-520
How to find answers ... FAQ559-1091
RE: iges files
Also, is this iges file a known good file or something that you just downloaded from the net?
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NVIDIA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
RE: iges files
make sure to check your iges options when opening the file. There's an option button in the file open dialog panel
Macduff spin
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2006 SP 4.1
Dell 380 XP Pro SP 2
nVida Quadro FX 3450/4000
