Assy problem.
Assy problem.
Let me start from the top.
I have a cabinet door assembly consisting of:
A door panel prt
A hinge assy
A rack part with two patterened instances
I created a top assembly with the cabinet body, insert
the door assembly.
I make the hinge assy and door assembly flexible.
Now when I swing the door, everything moves as expected,
except the two patterened instances of the rack part.
Does this sound normal for patterned parts. I'm on swx05
sp 0.0 so a bug is certainly not out of the question.
Any thoughts...?
A door panel prt
A hinge assy
the door assembly.
Any thoughts...?
RE: Assy problem.
SW06 SP5.0
Flores
RE: Assy problem.
It's fully constrained as well.
The patterned instances don't follow it which is
totally confusing...
RE: Assy problem.
Have you somehow mated/constrained the racks to the fixed hinge-half?
RE: Assy problem.
RE: Assy problem.
be spotwelded...it moves fine...it's 2 patterned
instances don't...and no ctrl-q doesn't move
them...I don't want to beat this to death, I'll
just delete the pattern and add 2 more copies of
the rack part.....this has got to be a bug...
RE: Assy problem.
it didn't work either...dunno...
RE: Assy problem.
SW06 SP5.0
Flores
RE: Assy problem.
little used forgotten things...lol
RE: Assy problem.
Someone has got to have a moveable subassy they can
pattern a part on to try this.
RE: Assy problem.
1. Create a part
2. Add two instances of said part to a new assembly
3. Add mates to create a hinge-like movement
4. Insert a third part to be patterned
5. Mate to moving part
6. Create linear pattern of third part
7. Insert this assembly into another assembly
8. Add mates to fix position of subassembly
9. Make flexible
10. Move hinged part
All my patterned instances move just fine. I'd be willing to bet it's a bug.
RE: Assy problem.
my boss to upgrade........................yeah right.
It's friday, consider this thread closed....lol
