How to export Model to Layouts
I have a model in autocad 2004 that has over 70pages. to print them on my laser printer I make layout from every page and that I print the layout. Is there any shorter way to print all pages from the model, or to export all of them in .pdf .jpg or something...
RE: How to export Model to Layouts
"Everybody is ignorant, only on different subjects." — Will Rogers
do you have 70 layouts now? There're some ways to plot them, if you have used the command "_PAGESETUP".
Then You can use the publish command.
Or you can click on all Layouts with the UPPERCASE-KEY (-what's the right word in english?-) and then open the plotdialog...
Maybe there's a lisp in the www for that.
If you have the pages only in the modelspace, I wouldn't know any way. Maybe an expert can tinker a tool...?
HTH, Lothar
Lothar
ADT 2004
ACAD 2002
@borgunit
...accelerated tempo...
ADT 2004
ACAD 2002
on your laser printer. Correct terminology s/b printed or plotted.
Assuming that you have done page setups for all layouts, pick all layouts by pressing the control key, then you will be able to plot each layout, continuously, one after the other one using the "plot" command under the file pull down menu.
When you access the plot dialogue box, only one folder "plot device" will be presented ,then select the appropriate choices under "plotter configuration" and "what to plot", then OK.
Test a three or four layouts at first.
