Absorption Chilling Optimization-retrofit possibilities
Is it possible to retrofit within a Water-Lithium Bromide absorption chiller an heat exchanger between the absorber and the generator ?
Do you know any manufacturers that proposes this feature "off the shell" ?
Thank you
Thank you
RE: Absorption Chilling Optimization-retrofit possibilities
The only thing we did in the heat flow to the chillers was we had a trim heater/cooler to minimize the temperature swings in the heat input to the chillers.
