How do you insert a proxy 3D Autocad file into inventor
I have a model drawn using Autoplant and want to use this model in Inventor! . Inventor will not recognise the proxy graphics. Can the proxygraphics be converted to solid or is there another way to import the model.
Cheers
RE: How do you insert a proxy 3D Autocad file into inventor
Have you tried exporting the autoplant file as a .SAT, then bring the .SAT file into Inventor? What other formats are available to export to?
