under floor heating
under floor heating
I am designing a under floor heating system for the first time
Where Can I find design guides and info on this subject on the www?
RE: under floor heating
TBP- Yeah! wood, however this does not help mechanicaldup. If I were him, the first thing I would do is to surf the internet for the research.
Try www.heatinghelp.com for books & info on these systems, along with conventional hot water and low pressure steam heating systems.
I have electric under flor (tile) heating in mind
If you are going electric, give some thought to servicing the resistor elements.
B.E.
* but then I guess it all depends where you live too!*
Bubz
Electric underfloor systems work very well as night storage systems. The only dis-advantage I have seen is that they tend to be about a day behind the weather.
This can be a nuisance if it is cold one day and hot the next.
B.E.
Use lots of zones, and keep the zone control valves accessible.
[ My own suggestion; redundant zones, at least where you're casting the tube into concrete. ]
Mike Halloran
Pembroke Pines, FL, USA
