Protection work Connecting Drain to River
Any expert please advise and where can I obtain the details of the connection protection work for a drain discharging to a river. Your advise and assitance shall be very much appreciated. Thank you!
RE: Protection work Connecting Drain to River
Could you add a little more detail?  What is drained?  What type of discharge to a stream or river and what kind of permits are in place?  Some discharges are allowed and protection is not needed.  However, discharging a wastewater or water from a process might need different methods for different applications.
Not to mention different river characteristics, flood elevations, currents, sediments, bank stability...
BigInchworm-born in the trenches.
http://virtualpipeline.spaces.msn.com
The outfall drain is 1.2m wide x 1.7m depth discharging normal urban surface runoff stormwater. The discharging drain is perpendicular to the receiving river of 40m wide and the discharge point is about 500m from the river mouth/sea. High tide is +1.7m and the drain IL is +3.6m. The protection work for the connection of drain outfall and receiving river is bascially to prevent erosion of the river earth bank of about 50 deg measuring from horizontal. I hope that this info is adequate for your advice. Thank you!
From the sound of the specific conditions/location you are dealing with here, I wonder if the U.S. Army Corps of Engineers (USACE, e.g. with work done/publications of their Vicksburg, MS facility) might be resources potentially helpful for the protection you need for this drain?
rconner, can you please give me the website where I can view the details. Thank you.
I don't know about "details", but I think a portal for the facilities/work I'm referring to may be http://chl.erdc.usace.army.mil/ (e.g. notice "erosion control" etc. links)
http://www.usace.army.mil/publications/eng-manuals/em.htm
also try this link for army engineering manuals, several of which deal with coastal engineering, flood control, drainage and erosion control, river hydraulics etc.
