VFD on 600HP centrifugal Compressor
Hi all,
Is that possible to apply VFD on 600HP centrifugal air comrpessor? It is 460V and using inlet and bypass valves as the control.
Also, what would be the other methods to control and saving energy?
Thanks in advance.
Thanks in advance.
RE: VFD on 600HP centrifugal Compressor
JRaef.com
Eng-Tips: Help for your job, not for your homework Read FAQ731-376
To avoid risks of premature motor failure, verify that the original manufacturer considers it “VFD Duty Type”.
The only thing I'll add about air compressor retrofits is to watch out for minimum speeds with regards to lubrication. Some machines use mechanically driven lube pumps which stop working below a certain speed. If it is a problem, many people just replace the lube pump with an electrically driven constant speed version.
JRaef.com
One place raved that they are going to have less than a year ROI for a 30HP they just installed.
Keith Cress
old field guy
Keith Cress
JRaef.com
