Kiln Dried Sawdust?
Kiln Dried Sawdust?
Kiln Dried Sawdust?
I was wondering if anyone has experience using kiln dried sawdust for moisture control as opposed to cement kiln dust.  Any help is appreciated!
RE: Kiln Dried Sawdust?
I do not have direct experience, but many years of observing physical, thermal effects on many materials, I offer the following.
Kiln dried sawdust will give a "mild" drying effect.
Cement kiln dust will give a "large" drying effect.
Many tables show cellulose vs. equilibrium data.  Books have been written on the subject.  Do a literature search.  Not so many tables for kiln dust, but the Portland Cement Institute maintains good library information on such data.  It's worth a look.
What type of moisture control? On what environment? What are you trying to extract the moisture from? We use klin dried sawdust extensively to stabilize drilled cutting from O&G operations.
