breakinfg an polyline
Hi there
I'm doing a culvert design and need to insert cross sections into the desing program. at present I use cross sections at 50m intervals. I need to break my polyline(representing my river) into 50m segments. is there a way of doing this? at present i have to measure manually and it takes time as my polyline as bends in it.
thanx
RE: breakinfg an polyline
Could DIVIDE be what you are lloking for?
"Everybody is ignorant, only on different subjects." — Will Rogers
I thought about DIVIDE, too, but you'll need to extend/trim your PLINE to be a multiple of 50 in order to get 50m segments.
That, and I don't recall if DIVIDE actually breaks the lines/curves or just puts the points onto the PLINE.
How much do YOU owe?
http://www.brillig.com/debt_clock/
it does not seem to break the pline onto the segments. What is the function of it then?
The divide command will put points (nodes) at 50m intervals along the polyline. Set your pdmode to something other than 0 to see the points better (a setting of 3 will show as an X). You can use the following macro to break the polyline at the points.
^C^CBREAK \F nod \@;
____________________
Acad2005, Terramodel
thax so much lpseifert. it worked just fine. the macro did not seem to work. I'll just break it manually.
thanx alot
I found a lisp, that would do that automatically.
1. _divide or _measure-> points
2. the lisp
CODE
(vl-load-com)
(defun BREAK-PKT(L LISTE /  LASTOBJEKT)
  (setq LASTOBJEKT(entlast))
  (command "_break" L (car LISTE) (car LISTE))
  (if (cdr LISTE)
    (progn
      (Break-PKT L (cdr LISTE))
      (if (entnext LASTOBJEKT)
        (Break-PKT (entnext LASTOBJEKT) (cdr LISTE))
(defun BREAK-PKT0( L /  PKTL LISTE INDEX)
  (if (setq PKTL (ssget "_x"  '((0 . "POINT"))))
    (progn
      (setq INDEX -1)
      (repeat (sslength PKTL)
        (setq LISTE (cons (cdr(assoc 10 (entget(ssname PKTL (setq INDEX (1+ INDEX)))))) LISTE))
      (if(setq LISTE(vl-remove-if-not
                      '(lambda(X)
                        (equal
                          (distance
                            (vlax-curve-getClosestPointTo (vlax-ename->vla-object L) X)
                            X
                          0.0
                          0.001
                      LISTE
        (Break-PKT L LISTE)
(defun c:BREAK-PKT( / L INDEX)
  (setvar "cmdecho" 0)
  (command "_ucs" "_w")
  (if (setq L (ssget '((0 . "LINE,*POLYLINE,ARC"))))
    (progn
      (setq INDEX -1)
      (repeat (sslength L)
        (BREAK-PKT0  (ssname L (setq INDEX (1+ INDEX))))
  (setvar "cmdecho" 1)
  (princ)
ADT 2004
ACAD 2002
how do i install/use the lisp
thanx for the help
From the point command, use MEASURE--it work as I just tried it but be careful on the unit selection under "UNITS".
