Gerber file in protel DXP
Protel DXP generate gerber file of an internal power plane in negative view. How can i generate these files in positive view ?
Thanks in advance
Glauberto
RE: Gerber file in protel DXP
ALL the PCB vendors I have worked with want the planes in the negative view.
Steve Smith
Steve Smith, C.I.D.
Product Engineer
Staco Energy Products Co.
www.stacoenergy.com
I'm not sure what you're after. Do you want to view them in the positive rather than the negative or do you want to make postive film rather than negative?
In DXP to view the Gerbers in the opposite, from Camtastic slect "View" then "Views" and "Negative". OR, you can just hit the N key.
If you want to change a layer from postiive to negative, from Camtastic select "Tools", then "Film Wizard", then click the "Neg/Mirror" and select which layers you want to mess with.
After Gerber files are generated, positive on negative film is controlled by the Gerber viewer tools the vendor has, and what film the vendor uses. If you send film to the vendor, and he only has negative, he can quickly make a contact print of a negative to get a positive.
