joining copper to copper
I'm trying to WELD C102 to C102 oxygen free copper to oxygen free copper using some means. Welding tube to header for hermetic sealed joint.
Use: Condensor using water - 2 phase flow
Weld joints are small.....03" wide x .75" diameter flange.
thickness of flange is only .006" being joined to a .03" thk base.
Who is in the business of doing this?
RE: joining copper to copper
it's fairly economical and there are heat treaters that do this provided the size is within their work envelope
Tim
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
http://www.metglas.com/products/page5_1_1.htm
