Boiler Efficiency
Boiler Efficiency
Alright, so I have a boiler right now. The company of the boiler went out of business and I'm left with no spec on this boiler at all. What ways should I go to find the efficiency of this boiler so I can compare this with a newer boiler?
Any suggestions would be greatful. Thank You
RE: Boiler Efficiency
What fuel is used to fire it? Perhaps you can determine how much energy you are putting into from usage figures and how much you are getting out?
good luck!
-pmover
I'm guessing the eff. is 70 to 80 %.
good luck, rjoaks
http://www.cbboilers.com/
What kind of instrumentation do you have ?
If u want to get the overall boiler efficiency u need to find out the energy going out through the hot water (MCP elta T...)
If you don t have any instumentation at all u could consider measuring the flow with an ultrasonicflow meter, and the delta T with surface temperature probes.
I was given an old method of using O2 and flue gas, but it did not take into the account of the Radiation and Convection losses. After looking at the website, this makes a lot more sense.
rnip
Hello everybody:
On this site you can find some comments on this subject.
www.energybooks.com/pdf/4453.pdf
Good luck !
