line scale in ACAD
line scale in ACAD
I just tried loading and using the center linetype in ACAD but I'm just getting a continous line. I tried changing linetype scale and the different types of centerline but I just can't get a cl.
Any suggestions.
Any suggestions.
RE: line scale in ACAD
2. Yout LTSCALE may be much too small so looks continuous. Zoom in on it.
3. "list" the line to make sure it has linetype you think (or on layer you think)
4. make sure your "shademode" is 2d.
This method works for about 80% of all drawings if done at the start of new drawings. If this does not work you will need to change the SFV of that line under the property of that line.
Since drawings may be complex with different scales when plotted, if changing to a new SFV for that line does not work you may want to go in the opposite direction for a value and that is selecting a fractional value such as .5,.01,.005 or others until you get the result you want.
When you are in layout and open a viewport, you will see that line as a solid, therefore, type psltscale and change the default value of one to zero, then type regen but before you do make sure that the bottom tab is change to model space while you are still in layout.
