Layers in viewports
Layers in viewports
Layers in viewports
Is there a way to have two viewports on the same layout, with different layers shown in the two viewports?
I want to show some highway pavement marking changes I'm proposing, with the existing pattern in one viewport, and the proposed pattern in the other.
Thanks in advance for any help you may be able to provide!.
     "...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
"I'm searching for the questions, so my answers will make sense." - Stephen Brust
RE: Layers in viewports
VPLAYER command
Or can get the same effect using Layer Manager, working through the viewport, "freeze in viewport" icon.
Thanks, Carl. I had just figured it out myself!
