Helical gears created using Toolbox
The values for pitch diameter and outside diameter are incorrect according to Machinery's Handbook Edition 24 page 1939. Anyone else come across this? Specifically: 18 tooth, 19.463 Helix Angle, 20 degree pressure angle, 2.0 nominal pitch. Thanks All.
RE: Helical gears created using Toolbox
Another good source of gear details is
http://ww
You could use the 10 day trial of GearTrax from
http://www.camnetics.com/Download.htm
