Reading from .mat files
Hi!
I've got a problem - I set up a laboratory experiment in dSpace which is connected to Matlab and Simulink. I "told" the experment (or simulation, whatever you want to call it) to save the results in a .mat file. And the question is, how do I extract the results from that .mat file?
Thanks a lot for your help.
RE: Reading from .mat files
I am guessing you want to extract the data for a report or to manipulate it more. To bring it into Matlab read this.
Then if you wish to export it to an exel file read this or get this script
I hope this helps
BsK
