Manufacturing Advanced Programming
Does anybody have any experience with "Manufacturing Advanced Programming" (NX4)? This module assists in programming machines that can simultaneously execute multiple channel NC programs.
The problem is, when I run Synchronization Manager I get the message
Failed to calculate machining times.
Error detected during ISV time calculation.
and, sure enough, can't synchronize anything.
I use the machine 2-CHANNEL_LATHE_MM_ the model and postprocessor for which comes with NX4.
I'd appreciate any information that might be helpful. For example, can anybody confirm that this 2-CHANNEL_LATHE_MM_ is actually working?
