Steam driven oil pumps
Does anyone have experience with Duplex Steam Pumps, or with other manufacturers of similar, or different technologies? I am exploring possibilities for the application of steam driven pumps for service with various types of oil to include turbine oils, paper machine oils, heavier gear oils and hydraulic fluids.
Any input is appreciated.
RE: Steam driven oil pumps
I suspect that even if you find a duplex steam pump, that the installed cost will be the end of your investigation. Good luck.
http://www.fhp.textron.com/da.htm
Here is a reference to the ANSI Specification for such pumps.
http://%
http://www.trainweb.org/tusp/r_links.html
http://www.dresserrand.com/steam/default.asp
