tea stains
tea stains
The white inside surface of my coffee mug had tea stains. Which cleaner removed the stains easily and why?
1. 409
2. Comet
3. Windex
1. 409
2. Comet
3. Windex
RE: tea stains
RE: tea stains
RE: tea stains
RE: tea stains
RE: tea stains
RE: tea stains
http://www.bonami.com/products/
RE: tea stains
Wikipedia suggests that the window cleaner contains ammonia, alcohol, dyes and fragrances diluted in water. Bleaching agents often contain sodium hypochlorite diluted in water. Wikipedia indicates that Comet contains sodium dichloro-s-triazinetrione dihydrate.
Avoid mixing bleaching agents with ammonia based cleaning agents. (this from a controls engineer not a qualified chem type dude)
The coffee and tea stains add character to the cup. A bit of detergent can be a good thing. When I want to rid a cup of the discoloration I use pure liquid bleach that eliminates the stain in seconds then rinse the cup - lots.
RE: tea stains
Sometimes I only open my mouth to swap feet...
RE: tea stains
E.g. don't spray ammonia/Windex on a cloth, then sprinkle on some Comet cleanser or spray a bleach-containing spray solution onto same.
The combination of ammonia and hypochlorite will form a dilute solution of hydrazine (yes, the rocket fuel), which is very toxic (causes liver damage). But, it's also a heck of a good solvent (will dissolve/destroy most any organic coating save fluorinated compounds), and works well to take creosote stains off the inside of a windowed woodstove door. The standard instruction "use in a well-ventilated area" would apply here.
