Manufactors Pedestrian Protection
Hello !
Can anyone help me with links too Manufactors of Pedestrian Protection WG17 ?
Regards SRR
RE: Manufactors Pedestrian Protection
What exactly are you after?
For details of WG17 look at the EEVC website (www.eevc.org) where you can download the WG17 document.
The ACEA commitment can be found at the following website: http://europa.eu.int/eur-lex/en/com/cnc/2001/act389en02/com2001_0389en02-02.pdf
If you want details of the manufacturers of pedestrian protection test equipment then you are best off contacting the test houses.  I know that TRL's test rig is made by Frazer Nash.  MIRA also have a full test rig - don't know who makes it.
If you want companies that are providing solutions then there are a large range.  It really depends on whether you are after a passive or active solution.  If you want more details on this let me know.
Hope this helps.
Hex
Our company developed a complete pedestrian protection system for a front hood as a prototype.
It's a combined mechanical/pyrotechnical system.
