2007 SW Explorer
2007 SW Explorer
Has any one else noticed that when renaming parts in the new SW Explorer the search for "where used' is painfully slow?
Rob Rodriguez CSWP
President: Northern
Vermont SolidWorks User Group
www.robrodriguez.com (updated 8/12/06)
SW 2006 SP 4.0 / SW 2007 SP 0.0
RE: 2007 SW Explorer
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe trumps reason.
Ken
These are 2007 files. I'm not sure if the issue is our network or SWE? The IT guys around here are virus paranoid and we are antivirus softwared to death (paranoya will destry ya). This may also be affecting the where used search?
I have specified only one folder to search (and there are only about 120 files in the folder, all SW)so it should be relatively quick. When you sit for about 2 miuntes waiting to rename each part it become a little annoying.
Anyway, thanks for the suggestions.
Rob Rodriguez CSWP
President: Northern
Daniel
You might be right. I thought I read at the SolidWorks Forum that the two were not related but I can't find the post I was referencing (it may have been on the beta board?). I have actually unistalled WDS because I found it would run in the background periodically and significantly slow my system down.
After a phone call with SolidWorks and some file exchanges it turns out the renaming issue I was having is a bug.
Rob Rodriguez CSWP
President: Northern
