Fdn. Drains Connect to Roof Drains
What are some opinions regarding foundation and underslab (slab on grade) drainage systems that connect to roof drains that connect into the storm water system. Are there concerns of backflow. What if the existing storm line pipe is below the foundation/underslab drains?
RE: Fdn. Drains Connect to Roof Drains
"...students of traffic are beginning to realize the false economy of mechanically controlled traffic, and hand work by trained officers will again prevail." - Wm. Phelps Eno, ca. 1928
"I'm searching for the questions, so my answers will make sense." - Stephen Brust
If we use a check valve on the foundation drain this would mitigate hydrostatic forces due to backflow water.
