Part Weight in Repeat region table
Hello all,
I have had a good search around this forum and the net for a solution to my problem.
I wish to put individual weights in a table on the assy drawing.
My model is in mmNs, and I want the weight in Kg's.
I followed this tut
http:// www.proece ntral.com/ portal/art icles/arti clesDetail .asp?id=34
But my units on the drawing dont corispond to the calculated mass properties in the model. I know the mass is in Tonne but thats simple to convert, this values isn't even close to that.
Any help would be great.
Thank you.
I followed this tut
http://
Thank you.
RE: Part Weight in Repeat region table
You can allways change the UNITS to mm Kg s. Create yourself a mapkey and repeat to all your parts and assemblies. I hope you don't have thousands in your top level.
And for thr future, setup units for template part, function of your needs.
Good luck.
-Hora
