Titanium welding specs
Hi, i'm not a welder but will be providing drawings for welding. i was wondering if i could get some basic specifications for welding titanium tubes. thank you.
RE: Titanium welding specs
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
I suppose TIG welding would be good enough for the cost but how to spec the weld so to get a quality weld is what i'm looking for.
i'll see if the libraries carry the D17.1 specs
http://mmptdpublic.jsc.nasa.gov/prc/7181b.doc
http://ww
http://www.deutschetitan.de/eng/profi/kb11.html
http://www.timet.com/pdfs/ti-handbook.pdf
You may wish to see the chapter 5 on Design for Welding from AWS Welding Handbook, 9th Edition Vol. 1
or read the article at
http://
http://www.welding-advisers.com/
You need to address a number of issues, not limited to; joint prep, cleaning, filler, welding control, and testing. You will want to pay a lot of attention to testing. Testing will be critcal. Both the destructive testing to qualify a process and the nondestructive testing to assure good quality in production.
Rust never sleeps
