Auto Incremental Numbering
Hi
http://www.eng-tips.com/viewthread.cfm?qid=138436&page=1
Thanks to Carlb. The answer is RH bracket was missing from first line.
The lisp is great for just inserting an incrementing number but what I would like to do is insert a item code as well. Something like XYZ1 : XYZ2 :XYZ3.  I know I could  multiple copy the XYZ part and then run the lisp to autonumber but that would mean aligning each one to look right.
Does anyone know of a lisp that will do the code and number together
Many thanks
Cadman
RE: Auto Incremental Numbering
If you have Express Tools,
Command: TCOUNT
will do this, but output will be formatted 1XYZ, 2XYZ, ETC., not XYZ1 : XYZ2 :XYZ3; the way you have it.
Engineering is the practice of the art of science - Steve
